1 - 3 of 3 Posts
Hello
When I change between 1st, 2nd and 3rd gears (mainly between 1st and 2nd) there is a definite "thud" like something is moving under the car. Any ideas what this could be?
confused.com
mine does this and the things i checked were,
engine and gear box mounts
propshaft joint (big rubber effort under middle of car ..should have some play but not loads)
do you have a limited slip dif? if so some of these are a bit clunky ..mine has a factory fit one and it would apear thats where my clunk is coming from..
Backyard Mechanic
Your car seems to have had every fault at one point or another m8! :D Is there any common skyline fault you havn't got? :)
1 - 3 of 3 Posts
