Hello everybody,
What engine oil do you recommend for 1993 GTS-t 2.5, think I'm due a service soon and would like to make sure I get the right stuff.
Abra
N
Guest
encontramos que los mejores aceites del quallity están de la variedad del aceite del hígado de bacalao, en 5/50
G
Guest
If you look at bottom of page there are similar posts . or as Martin said SEARCH
Dandy Highwayman
i tried the search and the links below and here's the digest ...
must be a good fully synthetic. castrol,millers,mobil,silkolene,motul etc. People here use a range of weights - 5w40,10w40,10w60,15w50
afaik factory spec is 7.5w30 but i dont think anyone actually uses that
by and large the higher oil temps you run the bigger the numbers you want... so
15w50 more for hot weather/trackday/high power use
10w40 more for cooler weather/road use
Registered (L)user
Wow, never noticed the links at the bottom before.
Made my night that has. I don't really get out much. :D
