1 - 17 of 17 Posts
Here's my engine spec....
Exterior:
FRP GTR front bumper with GTR grill
FRP Bomex sideskirts with rear spats
FRP Bumper with DTM air inlet for more airflow to air filter
Drag spec rear spoiler
painted rear skyline panel
NISMO clear indicator lens - front spot types and sides!
17" Rota GTR alloys
painted calipers
HID headlights with DUAL headlight mod
LED sidelights
Engine:
Blitz FMIC with hardpipe and silicon hoses
Blitz SUS air filter with adaptor kit
Full reconditioned coil pack
Spec 2 engine
Iridium plugs newly changed
painted cam cover, sparks cover, fusebox cover and radiator mounts
Trust exhaust system - all the way to the turbo elbow!
Hi-flow racing cat
Handling:
Nismo strut bars front and rear (tower type)
ARC thick anti-roll bars front and rear
Beilstein suspension with Eibach springs
ATS 2 way locking diff
Nismo suspension struts
Interior:
MoMo steering wheel with spare spacers if needed
Razo pedals and gearknob
LED interior light
Defi setup with water temp and boost
Autogauge air/fuel mixture gauge
The car supposedly has a 2 stage manual boost controller, but it's not used at the moment? Anyway, the car hits just over 0.5bar boost at the moment.
I was thinking the next mod should be a EBC? What say you?? :)
get a greedy boost controller and some sort of fuel managment ( apexi neo )
its there new piggy back fuel computer, it alters the afm signal to make the ecu either add or remove a set amount of fuel.
true, get a set of redstuff or yellowstuff front pads and change the fluid to new dot 5.1
Belgium/Netherlands Area Rep
aftermarket ecu or apexi safc2/neo and a mapping is what you need next and you will see 320BHP
Discussion Starter · #10 ·
So if you say EBC + AFC is gonna be about 400ish, then mapping on top (£250?)
Aren't you just as well spending an extra £100 or so and getting a Apexi PFC?
There's a sticky in the tuning section at the top on the order of how to tune the RB25DET.
Discussion Starter · #13 ·
I should have a unichip with boost controller module any day now.
Is it worth getting a FPR and Uprated pump before the unichip is mapped, or with the above mods is there no point at the moment?
i dont rate the unichip tbh, better getting a PFC if possible. Also if I was in your situation and had enough money for a new pump I would for piece of mind if nothing else, but I wouldn't say it was required as such.
Discussion Starter · #15 ·
I had a unichip on my old MR2 Turbo a few years back and it done the job great. I think for the time being it'll do fine. Possibly down the line if I decide to go mad on the engine side of things, then I'll need to swap for something like a Apexi PFC etc.
funny you should say that, there the only cars i have seen good results on. Not entirely sure why but it must be something to do with the stock map :)
Discussion Starter · #17 ·
I've seen good results on other cars.
Will just have to wait and see. lol.
Like I said in another thread. It can't be any worse than a EBC and AFC, can it?
1 - 17 of 17 Posts
