well i searched and cant find a guide
any links?
basically I'm looking for info. I've removed existing boss from an r32. and am installing a snap off wheel.
I got the HKB one (with hicas connector)
I removed the wheel and there was a whit circular disc that spun round a bit when I disconnected the horn connector/Hicas(I'm assuming) Where does this need to be? is it central with the wheels pointing straight ahead?
Also the hicas connector plugs into the connector on the column. where does the other end (spade connector) go? on the back of the snap off hub there's 2 flat conenctors for the spades but which one?
Arrggh.. pretty confused and dont want to mess it up further any links or help would be appreciated!
