Ok thats not bad and depends if you want to go about to remove that wing and bonnet and do it off the car as takes 5mins to take the wing and bonnet off the car and can either try yourself or have a spray shop do it.
Your paint code is on the Vin plate on the left of the bulk head.
Im doing a whole front end on my old car for the new owner as he had a slight acident in it and most of the parts all unbolt and well except front panel and main panels as they are spot welded on but still with a spot weld drill bit and a bit of time its all possible to remove these bigger bits etc.
All depends on your budget or try and find a wing and bonnet in same colour and just change them over. Try JDM on here. Has loads of spares etc.
