It will work fine. The rev limiter in the ecu is set to 7300. I did turn the Bee-r up when it was on the dyno as you had it set quite low for what I needed
Richard
Richard
ahh thats ok thenIt will work fine. The rev limiter in the ecu is set to 7300. I did turn the Bee-r up when it was on the dyno as you had it set quite low for what I needed
Richard
