Would the below spec turbo fit a Rb25det or is there more information needed to know this?
Turbo Spec:
Compressor wheel: 42 / 59.4 mm (inducer / exducer)
Turbine wheel : 42.4 / 49.4mm (Exducer / Inducer)
Compressor AR : 61
Turbine AR: 47
Compressor housing
inlet: 53.7 / 60 mm ( ID / OD )
Outlet : 42mm (ID)
A/R 61
Turbine Housing :
Inlet: T3 flange
Outlet: 52.4 mm (OD)
A/R 47
Turbo Spec:
Compressor AR : 61
Turbine AR: 47
Compressor housing
Outlet : 42mm (ID)
A/R 61
Turbine Housing :
Inlet: T3 flange
A/R 47
