Just go to Halfrauds and buy a set of Bosch ones, they even fit them for the truly lazy ones among us ;)
Monkey Shaver
they do! :doh:
The wipers have a water repellent effect that causes the water to bead up so you can ahead more clearly; they work really well but a bit expensive though.
BigBoy
I got the Bosch ones, with spoilers ?
Anyway, am having a thick moment here, how the hell do u change em ?!!!! i cant figure it out :( :(
There should a diagram on or inside the wiper blades packaging explaining
the art of blade replacement
Or just spend 5 minutes and look at the wiper blades then phone a friend
to come over and do it for you.
I wouldnt have bought the ones with the spoilers because they are
quite a bit heavier than standard and may slow the car down your
friend will probably know that anyway and may decide to break the
spoilers off for you. Good Luck !
