ok, so i bought an apexi avcr off ebay (hmmmm) wired it up according to the guide... boost max's out at 0.5 Bar! checked and tripple checked the wiring...all fine, but noticed when i turn the car on the solonoid doesnt click! so got out the tester and both black and red wires from the solonoid show live! is this right? anyway, the tester i used was just a light grounded to the chasis, and when the engine was on and the tester was placed to the pink wire the solonoid clicked!....so i re wired the earths to check theyre fine...all good, but no click! decided to try and earth the pink wire directly....solonoid clicked! took it for a drive....boost set to 0.85 Bar at 60% duty....hit 1.3Bar fuel cut out kicked in and i nearly got whip lash hehe!... anyone got a clue? (the unit inside the car is getting every reading...boost...throttle....revs....even speed although reading half due to converter)
any help appreciated!
Big Tom
ok...so without the pink wire from the solonoid earthed...no click from the solonoid when i start the car...with the pink wire from the solonoid earthed to the chasis i get a click....but the boost over shoots and the fuel cut off kicks in! (im 100% certain the boost solonoid shouldnt be earthed) but without the earth...no click....any other suggestions?
Replied to your PM mate.
