The standard afm on a skyline seems to top out at about 310hp, you'll need to fit an ecu before a bigger turbo, best bet is do exhaust and filter then front mount, then try and do boost controller+ecu+z32 all at same time to be setup on a rolling road. If not setup will run like a PIG.
