Cepe said:
okey manage to work out ignition and power suply and such, only thing i cant really make out of the diagrams is how the fuel pump relay is wired, anyone know?
The ECU's switching signal to the fuel pump relay is from Pin 18 on the ECU.
You will need to take the pin 18 wire from the old ecu plug and run it to the new plugs pin 18 tho, or I dont think it would fire up.
Was the cars original engine the RB20DET? or a non turbo lump RB20/25DE?
AFAIK the fuel pump should work as normal then, as long as the original wiring is still being used as well as the RB25's loom.
The +ve 12v supply to the fuel pump is from the (EGGS relay on 200sx) fuel pump relay.
I know the RB20DET's wiring includes a fuel pump power modulating thing, which I think is in the boot.
I dont have one in the S13, so the pumps at full speed/load all the time.
Possibly as your fitting an RB25DET now, it could be a worthwhile modification to bypass this too, especially when using an uprated pump, and running higher fuel pressures when under boost.
You may find you get a sharper fuel pickup.
I think it would be a good mod for any of the RB's that use it.
Only there to take a bit of strain off the pump, when ur not caning it about.
Here it is:
If you cut the fuel pumps earth wire at the pump.
Then tape the cut end which 'was' running to the pump, and run a good ground from the pump to the best earthing point you can, then it should be bypassed!
You might well find some benefits to this, but I dont really know if its something that many/any skyline owners have done.
